Hello. I posted few weeks ago without any luck because I was having problems generating maps from my tools without getting insufficient memory errors. I still have that problem sometimes but I have another, very similar problem as well which I would love to fix.
I have 8gb of ram, 3ghz hexcore amd cpu. Windows 7 64bit.
Sometimes when I try to load my tools, I’ll get an error telling me I have insufficient memory for my tools since they are too complicated. Then zbrush crashes. Sometimes all I need to do to fix this problem is simply start zbrush up again and give it another try, sometimes I’ll need 4-5 tries and sometimes nothing works, I’ll simple get the error again and again and again until I try again few hours or days later.
I’m currently having the problem on a model made of 6 million polygons which does not seem like a lot. My maxpoly setting in zbrush is set to around 21 million polygons. 6 millions is nowehere near that and yet I get insufficient memory errors when loading the model?
I’ve lowered undo levels to 1 in the preference menu with same random results. Sometimes it’ll load, sometimes it wont. I’m getting very annoyed because this seems so random.
Then when I finally manage to open my tool and try to generate a normal map, I get the error again and I’ll have to start from the beginning again.
Does anyone else have similar problems or perhaps know the solution?
