The trial installer does not work in OS X Sierra 10.12.4. If you try to run the installer crash.
The gatekeeper has been disabled using the command sudo spctl --master-disable. If you try to run the installer from the terminal it return the following message.
sudo /Volumes/ZBrush\ 4R7\ Trial/ZBrush\ 4R7\ Trial\ Installer\ OSX.app/Contents/MacOS/osx-intel
Password:
Unable to initialize installer.
Is /tmp writable ?
Could someone help me on this?
Thanks in advance
