Insta Crash with HD geometry :(
Well I got my model to a decent point and decided to try a small bit of HD modeling. So I hit the HD divide button (nothing happens).
Then I remember to save it first… I hit save and click ok to overwrite the previous file and boom crash.
OK so hoping the model saved… open zbrush and try to load the model… Boom crash.
I am now unable to open my most recent save as Zbrush crashes instantly with the info bar at the top saying “Loading 0 million high def polygons”
Has anyone else experienced this? My model is now totally unavalible to me cause I cant get it to open :cry:
What are your setting at Preference>Mem?
Andreseloy
ps:the model before HD what No Polygon have?
I have 1 gig of RAM and my memory is set to compact at 900megs or so.
Beofre HD modeling it was at a lil over 2 mill but I had all except the chest area hidden at the time so was down to about 560k polys on screen at the time it crashed.
for 1 GB RAM the set 900 or so is to high.
Play between 600-800
Andreseloy
Well mem is set to 750 now… unfortunatly thats not solving the insta crash on trying to load :frowning:
Your model has become corrupted. There won’t be a way to load it again. But the lower Compact Mem setting will help avoid this problem in the future.
If you have Windows 2000 or XP, then 756 is a good setting for Compact Mem.
If you have Vista, you should actually lower Compact Mem to 500. This is especially true if you run Aero.
sigh I was afraid of that… Ah well… I ended up remodeling what I had done the night before again.
Thanks for the help with the mem settings
