Insert mesh, size
Is there a way to retain the resolution of the curve (points), but resizing the acual object? If drawing an insert mesh curve, I know you can change it’s size with “drawsize”, this however also change how coarse the curve is. This isnt really a problem with small insertmeshes, but when using say a large strip for ex. a belt the brush becomes very small and resizing will make the curve to coarse to control. Any solution? =D
Settings in Stroke palette.
Thanks for the response Doug.
All I can find is the “curve step” mod. It does increase the curve resolution, but rather then adding more control points it compresses the mesh.
