Hi there, I work in photogrammetry industry and right now I face problem with exporting my subD scan.
Scene is castle first floor, created from 9 subtools - each one of them is at subD5-6 (27-90mln poly quad) with udim setup.
I have need to export all of them as single obj file (we use Atageo software to decimate models - better decimation algo compare with zbrush (UV island seams priority to be specific) that only work with obj and ply files) that works only with obj and ply
Export as FBX works ok, but above mention 100mln limitation is an problem with extended obj export feature.
Other thing would be to have decimation master working with something like “subtool seam aware” option to decimate them in way when verts on two different subtools borders are in same possition - so welding will be not a problem. - That would be huge.
Beside of that, it would be nice to see “feature request” button or something - I had and have huge problem to find correct spot to write above message
