When editing the original object that makes up a grid array, I would like that original object not to be in the corner of the array, but rather inside the array, how can I achieve this , Thanks.
You would have to create a multi stage array.. The original mesh will always be the first in the chain. You would have to create a multi stage array that repeats in multiple directions.
It shouldn’t matter, though. When you convert the array to geometry, all the instances will become live geometry.
Additionally, you are posting in the forum for an obsolete program version. Please upgrade your program if you have not done so, and post in the main forum to avoid your posts being overlooked.
Good luck!
Thanks for that reply, so I already have a two stage array here, but how can I get the array to repeat in muiltipel directions?
I figured this out, you create another stage for both axis and the drag the position slider in the opposite direction first used in the initial stages
