Hello,
I am importing frequently OBJ’s and have each time to navigate to the nested folder again and again. (This behaviour of not remembering used folders is so bad, no idea why it still wasn’t improved after years… Maybe the typical zBrush user doesn’t import or export or is a Zen master)
But once you provided me kindly a script, that remembers the last “export” folder.
I have attached it here below. Unfortunately I’m not able to understand how to write something like this.
Would it be possible to create a similar script, that remembers the last IMPORT folder, too?
Thanks for help!
The Export folder script, which is one of my most important scripts in zBrush:
//ZBRUSH MACRO - Recorded in ZBrush version 4.8
[IButton,???,“Export current mesh as OBJ using Maya settings”,
[IShowActions,0]
[IConfig,4.8]
[If,[IsEnabled,Tool:Export],
[VarDef,filepath,“ZBRUSH_ZExportImport”]
[If,[FileExists,“LastFolder.dat”],
[MemCreateFromFile,ExpLastFolderMem,“LastFolder.dat”]
[MemReadString,ExpLastFolderMem,filepath,0]
[IUnPress,Tool:Export:Grp]
//[IUnPress,Tool:Export:Mrg]
[VarSet,zF,0]
[If,[IGet,Preferences:Misc:Use ZFolders],
[VarSet,zF,1]
[IPress,Preferences:Misc:Use ZFolders]
[VarSet,toolName,[IGetTitle,Tool:Item Info]]
[VarSet,filePath,[StrMerge,filePath,toolName,“obj”]]
[VarSet,fileName,[FileNameAsk,“OBJ (.obj)|.obj||”,[FileNameResolvePath,filepath],“Export as OBJ”]]
[If,[StrLength,fileName],
[MemDelete,ExpLastFolderMem]
[MemCreate,ExpLastFolderMem,256]
[VarSet,folderStr,fileName]
[VarSet,bwritten,[MemWriteString,ExpLastFolderMem,[FileNameExtract,folderStr,1],0]]
[MemResize,ExpLastFolderMem,bwritten]
[MemSaveToFile,ExpLastFolderMem,“LastFolder.dat”,1]
[FileNameSetNext,fileName]
[IPress,Tool:Export]
[If,zF,
[IUnPress,Preferences:Misc:Use ZFolders]
,0.25]
