Import image 100% scale
Hey all,
I have an image scaled in photoshop to correct and specific measurements. Is there a way to import the image to scale, using the front-back map in the draw menu?
The scale slider set to 1 doesn’t seem to fit the correct scale for me, is there a workaround?
Kindest regards,
Gabriel
Hi Gabriel,
Welcome to ZBC!
You can change the Draw>Grid Size to suit the image.
For example, divide your image width or height by 1024 and then set the Draw>Grid Size to the result. This is based on a Tool>Geometry>XYZ Size for the mesh of 2 units - ZBrush’s preferred scale. ZBrush uses generic units so basically you can decide what ‘2’ represents - 2 inches, 2 meters or whatever.
This is quite a complicated way or working though. It’s not vital that you model at an exact size, provided everything is in correct proportion. You can set the scale of your model before export using the Scale Master plugin.
HTH,
Marcus
