Import/Export Problem [Zbrush 4 - GoZ / 3ds Max 2011]
[Zbrush 4 - GoZ]
[3ds Max 2011]
[Windows XP 32-bit]
Hello all,
I’m having a problem with the Import/Export.
Here’s my problem and my steps :
1. I modeled some generic meshes in 3ds Max 2011, then Export them manually to Zbrush4.
3ds Max 2011 Export settings :
See where is the NEW object now? There’s something wrong.
I tryed many things and I just can’t make it work correctly. It’s frustrating.
I really need to get this fixed.
Any idea why:qu:
Ty.
Have you tried resetting the xform in max before exporting? You can find the reset xform button in the utilities section of the command panel (the button with the hammer icon).
Ay, it’s a tricky this one, it’s happened to me a few times. I have found its when you delete subtools then re-import the body back into ZB, it adjusts the scales based on the sizes of the other subtools. Last time it happened I went back to the zb file which was ok and imported the new version (the one that is booged). Something to try, import a box which is bigger than the body, hide this subtool, that should keep the scale set even if you delete/change order of the subtools. Good luck anyhows.
