So I have an plane and I want to add some IMM parts to it. How can I keep the IMM parts as separate objects from the plane so I can edit them later?
Anyone?
- Turn on polyframe mode (Shift+F). This will show the polygroups and you’ll see that the plane has a different polygroup to the IMM objects.
- Ctrl+Shift+click the plane. This will hide all the IMM objects.
- Press Tool>SubTool>Split>Split Hidden. The IMM objects will become a separate subtool.
If you want to keep them all together as a single subtool you can simply use the visibility options I describe above to hide/show the different objects so you can edit them.
Thank you Marcus and Merry Christmas!
