Using the Curve Tubes brush, I draw out a simple Curve. If I hover to the end of the curve, I can manipulate and move the curve around. If I try and move the Curve from the starting point, the ENTIRE curve moves just as it would if I was moving it with the Gizmo. No the beginning point is not locked. Either points are locked. PLEASE HELP!! Thanks!!
Hello @TheCrookedLung,
If you want to be able to bend both ends of the curve, make sure that both Bend Start and Bend End are active in Stroke> Curve.
That did it! Thanks so much!!
