Is there a way to set the brush orientation in the picker menu to an exact 90 degree angle ?
Hi @zzeebee,
If you orient your target mesh towards you and snap the view to the axis, then press Shift after you begin to insert your IMMs, they should snap to that axis.
The following video may also be helpful:
Perfect. Thanks so much Spyndel !
