I have a brush I want to use, but when I apply it to a curve, it is fine except I want the orientation rotated 90 degrees. I know about holding control and rotating the stroke, but it is a large and complicated curve and only does a portion and a large brush just makes it look odd. What I would like to do is edit the base brush and just have it rotated 90 degrees. Any ideas?
I actually figured it out. I just needed to create a new mesh and then do mesh from brush, rotate the brush and then set the modifiers to what the original brush was.
