I'm starting to learn zbrush.... I've looked at clips on youtube but I don't understand
49:46 … can you guide how to get Mash of the wire
thank you
Hi @thai_bui
Select Move (W), hold down Ctrl key then click and drag on mesh.
I see the black mash in the middle of the wire… I can’t do it
mash ?? do you mean mask? ( if you are having trouble communicating in English, try using Google Translate )
The video link below is at the correct spot. Just click play button. Watch carefully (between 49:43 and 50:07) what he is doing and how he is moving the cursor. If it is working for him, it should work for you. Once you enable “Move (W)” and keep holding down Ctrl move the cursor carefully. You will get the same results if your mesh is the same as his.
https://www.youtube.com/live/VcFNRW4C4ic?si=S-Tsgtoz51Lhf9hP&t=2983
thank you so much
