I use [IGetTitle, 5570] all the time to get the number of subtools in my macros. The command worked until now but I get an error running it in ZB4R3. Anyone knows why and how to fix this ?
With an error of that sort the first thing to check is whether the numerical interface item ID has changed. You’re getting the title of Preferences>Misc>Subtools Count, aren’t you? In ZBrush 4R3 the ID for this is 5572.
Thank you so much. I was using the command without exactly knowing which interface command it was referring to. So now I know
