Hi, I was wondering if there is a way of knowing which polygroup the mouse clicked on and assigning it’s ID to a variable. There must be some way to do this since zbrush knows which polygroup to isolate when you Ctrl+shift+click on a polygroup.
i’m basically building a plugin which assigns pre-defined masks to a basemesh I use. At the moment it works using buttons in the UI but I would like to make it more intuitive by clicking directly on the polygroup which I’d like to effect.
thanks!
