Someone asked in another thread on how to create Icons for Zlauncher. I updated an old script to work in 2.0.
- Either Draw your Icon on the Canvas or press “Import” to select an image from the disk (if you Import it is best to select the “Flat Material”
3. To make a frame around the image, select an approprate draw size, Material and color and press “Frame”
4. If needed set up the render parameters and lights
5. Press “Export” to save the Image to disk - The “Save” dialog will prompt you to select a filename. To work with Zlauncher select the Zscript Txt or ZSC file that you wish to create the Icon for. This will name the image “SelectedZscript.PSD” .
7. If you haven’t already, load the desired zscript into Zlauncher and your new Icon should appear!
