What I want to do is Button in psd, but there is a part I don’t understand in relation to it.
For example…
[IButton,“test”,“testdrow_s”,
[IPress,Transform:Draw Pointer]
,50, “test.psd”, 30]
If you use ipress on ibutton, you can make a PSDButton that naturally uses transitionform:draw.
If you set it to Transform:, it will be disabled.
So the top level menu can’t be a psdButton?
[ButtonPress, “transform:”, transform]![]()
But you can create txtButton in case of ButtonPress of top level.
It seems to me that this is a solution to the problem.
Another problem is that ButtonPress can’t seem to make it into a Button if it’s a plugin.
But if you put it into ibutton, you will get an error.
Is there any way to fix this problem?
