Hello friends of Zbrush !
I´m really despaired. I really can´t work with zbrush, I do have always the same big troubles.
Crashing
ZBrush always crashes, if I use a higher divide level. If I do have about 700.000 polys, this is the maximum before I get kicked. -
Displcament
And all I can do, I always get not the right Displacment map. Very often my mesh goes into “nirvana” and I can´t see it. After that it´s not possible for zbrush to calculate the displacment map and it ends up with a one-gray colored image stored as alpha.
I don´t know what I can do ? It´s no fun working on tools - cause you can´t do any progress.
Is my hardware the problem ?
I do have:
2,6 GHZ AMD
OS Windows 2000
1,5 GB RAM
Is there any hardware minimum for making high quality 3d meshes I can see day for day in the featured gallery ?
If so, please let me know more. Of course, I can see big troubles in working with textures with 4096x4096. My Computer needs really a long time for calculating, etc… Or is Windows 2000 not possible to handle 1,5GB RAM ?
But my system tells me no errors and all other software packages works fine for me.
Thank you for every little help and sugestions.
the despaired little capu
