I have changed the recently IP address: 192.168.1.1 I used because when I connected to the other site always says that my IP address banned of the admin. I tried to find the solution on google. I tried everything I found on may forums except resetting router. But no luck. Plz tell me how to connect it again without hassle?
Well, it may happen because of spam which was sent from your IP. If you have someone use your computer that can be it. If your new IP allows you to access the website then it’s definitely that. If not it may be the problem with your provider. Try contact the support team.
You can also try to check on the site you are logging in, so that they can teach you fix that problem. For me if I experience that kind of situation I will always tell to the admin board so they can fix it after that. Or you can check their site at 19216811.me. They can also help to rid that problem, that you didn’t change your IP.
