How would you retopo the edges on the shoulder pads? I think there must be some quick way of doing it, to use a zsphere would be painful. The zremesher doesn’t perform well, maybe you could edit the zremeshed mesh but that would probably end up being inacurrate. How would you guys do it?
By hand. If you want clean topo that’s the only way to do it. If Zremesh doesn’t give you the results you’re looking for then by hand is your best option and possibly the fastest
Eight hours later, thank you, zbrush really needs a detect hard edges option for zremesher.
retopo of that object should be like an hour, tops. If it took you 8 hrs you need to practice working with retopo and modeling tools to help speed up your workflow.
