hi zber2,
tnx for your reply.   but, my problem is this…
when i hit the “ctrl” on my notebook, it registers as “ctrl+F4”. told you my keyboard is screwy. so every time i hit the “ctrl” the quick-pick panel opens up, same also when i hit “ctrl” and “z”…the quick-pick panel opens up.
some googling and i found out “F4” is the hotkey for the quick-pick.
more googling and i found out you can edit the hotkey assignments in the text file in Users\Public\Documents\ZBrushData\ZStartup\Hotkeys
so i added in these two lines inside that file[EDIT:UNDO,634] // Ctrl+F4+Z
[EDIT:TOOL:UNDO,634] // Ctrl+F4+Z
now, when i hit “ctrl” and “z”, i get both: undo and the quick-pick panel opens up. its a PITA to deselect the quick-pick before continuing on.
so, i figured if there is a way to make the F4 not assigned to anything then i am good.
any help?
