I made gloves.
I want to add thickness to the gloves.
Ideal (extrude to the middle point)
The flow of polygons is bad.
Can’t close the hole normally
How can I add thickness?
I made gloves.
Hello @beginner
The easiest way to add thickness to a high resolution mesh is to perform a subtool extract in Tool> Subtool> Extract, with a negative thickness value so that the geometry extrudes inward, not outward.
If this does not produce satisfactory results, I have produced an illustration of how I might perform the approach you are attempting. It would require too many words to explain in a forum post. It will require you to be comfortable with the shortcuts for hiding and working with Polygroups, as well as masking them. I will be frequently hiding portions of the mesh without further explanation. Just remember that you can hide or unhide polygroups by shift+ctrl clicking on them, and you can mask them, or invert existing masking, by Ctrl-clicking in empty canvas space.
Please feel free to ask specific questions about any portion you don’t understand.
Good luck!
Thank you for your reply.
I understand.
Thank you!
