Here this is what I stuck, want it to be slope like this image
Hello @redmyclan
The easiest way to go about this without modeling is probably to use Live Boolean with a cylinder set to subtract from a cube.
You could also use the Clip Circle or Clip Circle Center brush on a high poly cube. You would need to dynamesh this to clean up the geometry after.
