Since the RefSwitcher plugin no longer works and can’t get a response
, I need a way to toggle all visible subtools On and Off.
Is there a way to make all visible subtools – including the active subtool – disappear / reappear instantly via a macro or something
- without disturbing which subtool is active and which subtools have visibility on
- keeping the camera position exactly the same
Everything I have tried leaves the Active Subtool visible which defeats the purpose.
I want to toggle on / of the models to compare to the background images set in DRAW/CHANNELS/STORE_CAM. Toggling the “model opacity off/on” button leaves a ghost of the model obscuring the image. I can’t see a way to really set model opacity all the way to zero.
Thank you!
A Related question:
If a plugin that you love goes unsupported / unusable uncontactable for >2 years, is it possible/ethical to have someone else recreate it?
If so, how would a non-programmer do this?
The RefSwitcher plugin is great(!) but broken (at least with Mac) beyond ZB2022.
The .txt file is not included with the plugin.
