How to set transparency for ZBrush Palettes
How can I decrease the transparency of palette display in ZBrush?
Using 2019, question applies to previous versions I’ve used, all the way back to 4R7.
I would like to make the palettes less transparent, so I can read the menu items more clearly.
Thank you!
Preferences >> IColors >> Popup Opacity.
It’s that easy. :slight_smile:
Be sure to store your configuration after you’ve made the change so that it will be recalled when next you launch ZBrush.
Thanks. Works perfectly.
Found another useful transparency setting: Quick Info Opacity can be used to make the helper palettes more visible. Probably not using the correct term… I’m referring to the useful tips that appear when you press control, while hovering over most buttons and sliders.
