Hello! I’ve got this cube that I’ve created with an Insert Brush with Radial Symmetry, It’s not scaling properly, I want to modify the dimensions of the cube, how can I do this?
Thanks
Thanks
Hello @simonsanchezart
Do you want to modify a single cube, or all of the cubes? If you want all of the cubes to be a different size, simply Ctrl-Z, and redraw the cubes at the proper size with your IM brush.
If you want to modify a single cube, deactivate symmetry. You will need to mask, hide, or split the other cubes to a separate subtool.
It may be the what you want to do would be a better fit for Namomesh with the edit mesh functionality:
http://docs.pixologic.com/user-guide/3d-modeling/nanomesh/edit-mesh/
Good Luck!
