How do I rename or delete brushes within a IMM?
I don’t think you can rename the ones inside. I just make a new brush.
If you are trying to name the main brush you just save it and the name you give it will be its name, so if you name your brush file: MyNiftyWonderfulBrush.ZBP when you see the brush in the brush palllet it 4will look like MyNiftyWonderfulBrush, but likely truncated as there is a limit of 15-16 (honestly I can’t see that small so counting letters was tricky).
If you want to name the sub-brushes you would either do that while creating them, in the Subtool pallet you can hit the Rename button and then create your brush (it will use the active subtool for the name).
If you need to rename one that is already made you will need to sort of remake it (I think) and you can do this by taking all the parts out of the brush and using the rename thingy, you would do that by going into the Geometry Pallet and under Modify Topology you would hit the Mesh From Brush button for each one of the brushes, then rename them and append them to a new brush.
That should do the trick I think.
Cheers!
Mealea
Ok thanks guys, as I suspected there is no functionality built in yet. I’m assuming the same for deleteing one of the sub insert meshes too? Recreate the whole brush?
I’m guessing here, but yes?
I thought it might be possible to mess with the file directly but no luck it looks like total chaos inside, like this:
egþ_5a òM<PFYZ_^"ZOJa þ%0&(ó/38WU_meWHJQP C÷]Kwx}ªNO; þA=Pûœta_3a ñ2?@;IS_ac+2[O ý#(%&ò’(D28WS_leXPO3QÿO ûBDEK]wüz@P; öJ@aJ=TW…1 ï3?A5%8Zj-"_b^PD $å&(+Q38YR_mdYRJ0PNMQP9I<EKCOvûyNPQ= öC=JPSTUE, û4>?7)<õ=(*(#f_iQD "ð$’):3<^QaedZMK0ihJüRDFHCüRuw¡Qÿ= ûC=_HXTüVG0) î4>95>?A&’_g^kcRE ò!$@<^PY~vVOM0fþ^GFHöBDQE\wBRS@ õB=^FPTVWH<) ø:=:>?AB(’÷#<^d^keTE üH=[Q}éˆZLN>1PNGHGBNCDFBAId=U@ öK]FJUVXYN)a :ö?@BD(’&(N;^ûleTF øB:^Mm|~‹Lö7"KLDCH?@BEøCA:,.6QB öE[SGVWXZR) úP@BDF)&õ(#3;][_leUG ðJCLU{z9L7"FHNP=<þ@A@ýB8+1) ÷E\[FLXZ\V* (ûF8+/&(ö03:\XmfVG îC9VMyz€pLN980356796ûACD7,1ÿ) õ0>YEPY]Z,
ú$.)’(&(ô-39\W_mfVGJQ ûBC]KjxüMN: ü%/2/+û2H861ÿ) ö06>T^`_/ þ"%&(ô938\T_lfWPO3P ûBCEKTwû{=OP< ÷$(%&).3201ÿ) ö[email protected]:* %ñ&)*e27]R_meWQJ2NÿRO ûBCNDKvûy‰PQ<a û$%’)-) ü6@6+;ü9,?* å!"#%+):4;\RafdYTJ0jaNLKGECHCù\vuzPQ=" ö7?7,=?@&%& ú"!#(B=VðSqi^LK0efcMFGDHCøLJlwAQR?! ù9=8,>?A’þ&( òE;^Ox}‰¨L>I1PdGHÿKCûKIFN›Uÿ?" ú9:.?AD(þ&‘ ïM^N]|}†7L6"<AE@A?BûEFC?<5ýMAB" ûG.ACE(&ý#>KL øE;OQ|{ƒHLû7/CPQFþ<@DBú:/10,.# ú.BEF)(&÷’1>POMKLP ðM\Lvz£LN8’.3LC8;ú?<
So much for that bright idea!
