I noticed they make file huge if in 4k. How I can clean ztool and remove them?
Displacement, texture, normal?
Just click on the relevant thumbnail and select ‘Texture Off’ from the pop-up. But be sure to clone the map first as there’s no getting it back!
but this is it what I want to delete, even the clone I made. So when I open fresh zbrush and open ztool I don;t want to have in textures any old stuff, juts pure geometry.
That’s what I told you how to do. If you clone a texture map the clone ends up in the Texture palette, it’s not saved with the ZTL. And obviously you only need to clone the map if you want to keep a copy.
There’s no way to clear the Texture palette of it’s textures other than with a restart. But the custom textures there are not saved with ZTLs, or project (ZPR) files.
ah sorry, got it! Thank you !
