How to paint across subtools in zbrush 2018?
How do I paint a single (rgb or mrgb) stroke across more than one subtool at one time?
(I don’t see how to add cloned subtools to each other under the geometry “insert mesh”)
I often wish there was a way to paint multiple subtools at the same time however for the time being you must merge subtools together >Subtools Palette > Merge Down, or Merge Visible to merge all visible subtools.
After you have done this you can split them back to their own subtools - be careful however that you split whole subtools as you intend i.e if subtools have more than one polygroup per subtool.
