how do i mirror a subtool so that its perfectly symmetrical.
i want to continue sculpting on the x axis after adding subtools and want to keep the symmetry
If I understand you correctly, then Tool > Geometry > Modify Topology > Mirror and Weld is what you are looking for. It will mirror the geometry along the selected axis.
Note that the function only works in one direction, so it may sometimes be necessary to first flip your geometry with the Tool > Deformation > Mirror action prior to M&W.
thank you i appreciate your answer. Seems like the answer i was looking for.
Thank you you save my day!!
