How to lock a curve in position ?
Even with Bend disabled, and Start and EndPoint Lock Enabled, when I stroke along a curve I am still moving the entire curve around as well as getting the brush stroke (getting blue cursor). How do I lock the curve in position so it doesn’t move at all ?
Could you also explain what you are trying to achieve. Why do you want to lock the curve?
I am doing precise architecural stuff. I turn off ZADD/ZSUB and “massage the Curve” into correct shape and place with BEND on.
Then I turn LOCK START/END on & Bend off and just try to apply a brush stroke — then I want to change Alpha and Brushsize and apply another brushstroke along the curve so it sits deadcenter on the other stroke.
Here’s where I run into trouble since I am always slightly moving the curve around no matter what when I do a brushstroke.
Try using the Stroke>Modifiers>Replay Last button (hotkey 1). You can change alphas etc. but don’t reposition the model - that will count as a stroke.
