Hi all!
I just totaly crashed my new install of windows XP x64 edition by installing JAVA yesterday…
You need JAVA to install Zbrush, and there is no java for amd64 yet.
So how do you go about installing Zbrush? Simple,
You need a 32 bit Windows partition…
Just partition your hard disk into 2 or more parts… and install 2 versions of windows… 1 64 bit and 1 32 bit.
Install JRE from the 32bit partition, then install Zbrush, make sure you got Zbrush all installed and working, and then simply Boot into your 64bit partition, locate the Zbrush folder in the other partition, create your shortcuts, and run Zbrush
it will make you re-enter your POP information, and then it should run… Hell, not run, it will FLY!!!
Hope this helps someone out
small_orange_diamond
