I’m starting to use pictures as background images when building characters in ZBrush.
How can I get more precise control when adjusting horizontal offset for a map I’ve set to be the background of my front isometric view? I realize I can keep typing in different numbers, but that seems like extra work just to obtain a result that is best decided based on visible feedback (in other words, does the center line of the picture match up with the center line of the canvas?)
Maya allows three different settings for how quickly a mouse movement will update the numbers displayed.
When dealing with a starting value is 0.52219, dragging the slider does not produce a precise result. I end up having to type in 5 or more numbers (hi, low), to get the value right.
Thank you.
, the adjustment is actually found in Preferences:Interface.
