is there a way to export the haircut created with fibermesh with zbrush into keyshot or any other software?
I have created a model with curly hair but i have difficult to export this haircut
Hi @DajeZbrush
When you are happy with the FiberMesh, you have to click the “Accept” button in “Tool > FiberMesh” which will create a separate subtool. You can then select that subtool and export that with “Tool > Export” and select whatever format you want. If you want to export it with other subtools, you will have to merge whatever subtools you want to export.
If that isn’t it, you will have to better explain your “difficulty”.
Ok thanks , but i have a problem: I already accepted my fibermesh and now I have something like 4mil of active polygons and I Have difficult to export the fibermesh in a lighter version. but this is my situation and I got stuck. I don’t know whether I wuold better of create the hair from scratch again but with maya or to adjust the already fibermesh accepted. is there a way to reduce the fibermesh already applied in size right now?
I don’t know whether I am writing in the right section or not.
