How to edit your model / mesh after insert a tube?
Hello,
I want to add a curve tube snap brush to my model. How do I edit my model or edit them together again after I insert the tube? It darkens my model and can’t edit anything but the tube. Any tutorials or way to do this? Thanks
You can clear the mask by holding ctrl and dragging somewhere on the empty document, or by using Tool: Masking: Clear
Cool, thanks…
How do I go back and re-edit the tube I inserted?
The tube should be it’s own polygroup after inserting it, which will allow you to visually isolate it by ctrl+shift+clicking on it. You can then edit it from there, or mask the rest of the mesh (manually or with polygroup automasking).
You wont be able to go back and edit the curve itself once it is gone however.
