How to delete all zremesher guides at once?
Is there a way to quickly remove all the zremesher guides at once?
If you click once on your mesh (without drag) it clears all the guides… Alternatively you can go to stroke / curve functions -> delete…
Thanks Regnas! That helps a lot! :smiley:
On the reverse of this… How do you delete just one guide? A single guide that might have been added wrong? Whenever I click and hold Alt, and then click on a guide, it just ends up deleting all of them. :-\
I definitely feel like the ZRemesher Guide brush needs some adjusting/fine tuning… It really doesn’t appear that you can delete a single curve (unless I’m missing something) and the curves very easily merge into others if they’re too close. Plus, unlike other curves, there doesn’t appear to be any way of moving them when you hover and click on a circle. Other curves seem to let you move/reposition them.
