I am assuming that you are talking about doing this within ZBrush for this answer. Depending on how many polys are in your head there are a couple of options:
- Make a copy of your head by duplicating the subtool.  Mask the polygons you want to separate. Press Control + W to make the masked polygons a separate poly group. Then Subtool>Split>Group Split to separate the mesh by its polygroups.  You should now have 2 separate meshes, one for the head minus the jaw and 1 for the jaw.
OR
- Make a copy of your head by duplicating the subtool.  Now using shift + Ctrl carefully select the areas you want to have as a separate mesh being careful to make all other polygons not visible.  Now mask these polys that are visible. Then select Subtool>Split>Split Masked Points.  You should now have 2 separate meshes, one for the head minus the jaw and 1 for the jaw.
Depending on how many polys you have, it can be tricky to get just the right polygons selected, but with persistence and practice and a combination of the techniques above, you should be able to get what you want with a head mesh of ~ 10K or under.
Good luck.
