How to customize UI
I would like to custumize UI in order to arrange brush buttons in two rows in the bottom window using "Enable Customize"function.
But I can only arrange them in only one row.
If anyone knows how to do it, could you tell me it?image1221
Drag a brush to just below the upper brush icon and the UI should expand. Sometimes it’s touchy. One way to help is put a large UI element in place temporarily to open up the space on the UI. For example, put the color swatch, Stroke:Frame Mesh button, Brush: Depth icons or similar in place. They are at least two normal brush icons deep. Drop another copy under the first to open up four rows of the UI. I have managed to get about 6 or more rows in the bottom part of the UI this way.
I was able to do it with the method you taught me!
Thank you so much!
