How to create .zsc from the .txt file?
when i modify/write a script in a external software instead of recording it, how do i create a .zsc from my .txt file?
in case anyone is looking for this: when a txt file is loaded in zbrush then it creates a zsc file of it in the same location.
Be sure to delete the whatever.zsc file should you edit the text file or it’ll use the old .zsc instead of your edited version.
