How to create a Stencil with 1024x1024 pixels?
  • I created an alpha map inside photoshop, 1024x1024
  • I import that alpha into Zbrush
  • I create a Stencil
The Stencil itself, is not 1024x1024 inside my viewport.
Video: https://youtu.be/XVQWhzexp6s
Hello @FattyBull ,
The alpha is already sized at whatever the resolution you imported it as for the purpose of applying that alphas effects. The display of that alpha in the viewport will be relative to whatever the canvas size is, controlled by the document dimensions. The alpha can occupy a much greater or smaller pixel space on the canvas depending on how large the canvas is, and how large or small you have scaled the alpha to dsiplay on the canvas.
If you are trying to create an image at a specified size, then set your Document dimensions to that size, and fill the entire Canvas with the image.
The following information may be helpful:
http://docs.pixologic.com/getting-started/basic-concepts/
Good luck!
