How to close the main folders screen?
:cry: Im new in zbrush, i came from maya and unity. so, i dont know this simple thing. Someone can give me a tip?
i found a way here. Just click in button called “LightBox”. So this enable and disable the screen.
If you’re referring to the Lightbox pop-up that opens at startup, it can be hidden either via the “,” key, Lightbox button, or the “hide” button in the top right of the lightbox menu panel.
If you’d like to prevent Lightbox from opening at startup, the control is in Preferences > Lightbox > Open At Launch (disable, then “store configuration”). There does appear to be some sort of bug where the function gets re-enabled as soon as you store the config, but as long as you store the config while it is disabled, it should not open the next time you start zbrush.
Thanks this was really helpful!
