How should I use the script to get the number of IMM
How should I use the script to get the number of IMMSnipaste_2021-12-11_12-15-53
I think:
[IGetMax,Brush:Modifiers:Multi Mesh Select]
should do it. Because the slider starts from 0 you will have to add one to the result.
Marcus
Thank you very much. I solved this problem. I have another question. How should I turn all imm brushes into sub-tools at the same time?
I don’t think there’s a way to do it at the same time. But you can do it like this:
    //get number of IMMs
	[VarSet,noIMMs,[IGetMax,Brush:Modifiers:Multi Mesh Select]]
	[VarInc,noIMMs]//add one as slider starts at zero
	//loop through them
	[Loop,noIMMs,
           //select IMM
		[ISet,Brush:Modifiers:Multi Mesh Select,[Val,n]]
            //create mesh
		[IPress,Brush:To Mesh]
		[If,([Val,n]==0),
			//record first new mesh ID
			[VarSet,toolID,[IGet,Tool:Item Info]]
			//get name of the new mesh
			[VarSet,newMeshName,[IGetTitle,Tool:Current Tool,0]]
			//record its ID
			[VarSet,delToolID,[IGet,Tool:Item Info]]
			//reselect first mesh created
			[ISet,Tool:Item Info,#toolID]
			//append new mesh
			[IPress,Tool:SubTool:Append]
			[IPress,[StrMerge,"PopUp:",[Var,newMeshName]]]
			//reselect last mesh created
			[ISet,Tool:Item Info,#delToolID]
			//delete it
			[IKeyPress,'2',[IPress,Tool:SubTool:Delete]]
	,n]
Marcus
Thank you so much
