How do you tapper Zmodel left or right
How do you tapper a none zsphere thin Zmodel left or right
mask the side you don’t want deformed…tools:deform:taper…either x,y, or z depending on the how you want to deform it? would be my best guess.
There are many different possible ways to do something like this, depending on the exact effect you want to create. I might try something like this: deform your object to make it thin first. Then, move the object’s center so that the center is at the bottom of the object, in the middle, more or less. Then use the Taper deformer to taper the object, and finally, use the Skew deformer to slide the points left or right; the ones at the top will move over more than the ones at the bottom, so the result is an object that tapers toward one side.
Thanks aminuts
and
Thanks Muvlo
I used the offset and brought the axis to the bottom of the ztool in edit mode
Movlo would make a zscript using Z2’s 3d plane tool then show the tapper if you have the time.
