How do I weld?
I have two sub tools. How do I weld them without mirroring them?
In the subtool pallet you can use the merge function to merge and weld two meshes together. Alternatively you could merge the two subtools, dynamesh them then use zremesher.
Hope that helps.
Alright, good idea. Thank you, Sir.
Is that the way you would merge these tentacles with Cthulhu’s head?
Yes you can use Merge for your tentacles too.
