How do i render hair? When i render the hair doesn’t change, its still so ugly even if i render… i have activated fibers in the render option and still get so ugly. Why is that? How do i fix it? Help!
Hi Bloody(Magic, I haven’t worked much with hair other than a couple playing around tests, but if I understand your question,…the changes you’re making in the material panel doesn’t change in the render? Are you using ‘Best Render’? I think this is required for fibers. Also, is it possible you may have baked the layer? My best guess. Zya. 50.
Just for you…just an example quick alien thingy and I slapped some hair on it…hope this helps…when runnign the script be sure to put show actions on…
RedHairAlienExample1.TXT
did u use the fiber brush or the fiber material???
