How do I find a plugin to export my zbrush to 3d max
Hello all, I am new to Zbrush, and I find it really nice. I am confused as I dont know how to export from Zbrush to 3D max which is my normal 3d package, can anyone give me guidiance on how to go about it? It would be most appreciated.
Cheers!
From Max:
Select your mesh
>File
>Export Selection
>Select “OBJ” from the file type drop down menu
>Name and save to a folder of your choosing
In ZBrush:
>Tools
>Import
>Select the OBJ file you just created (BTW; it’s typical that the mesh comes in upside down)
>ZBrush with madness
Reverse flow in the other direction if you start in ZBrush. Use Export in ZB and Merge in Max.
HTH
—Chaz
You should read the ZBrush Guide ( on this forum ), it contains everything you want about ZBrush. An excellent beginner’s guide.
Bye !
Thanks very much, your views were highly appreciated. And it worked, I 'd say its easier to model in Zbrush than it is with my 3d max. So any new tips you can share to help my Zbrush experience?
Thanks
