how do i drag textures on zbrush?
ok guyz! i wanna know this, how do i drag my colored texture onto my model in zbrush? the same way as you click and drag alphas?
ive seen it done but cannot find the answer anywhere!!!
lets say i have a model of a face, ok? then i find some nice colored skin textures how do i drag the textures the same way as you drag an alpha?
please help me!!!
im goin mad!!!
thanks!!!:+1:
If you want to do it in zb viewport with symmetry and all you need to use polypainting.
First disable UVS.
(export your level1 as .obj beforehand if you want a backup of your uvs)
Select the standard brush.
Choose drag rect stroke for example.
Load a texture.
Be sure COLORIZE is on in texture palette.
Add subdivide the model up to the vague chart below.
2048x2048 texture size =4to5 million polys
4096x4096 texture size =15to20 million polys
Now disable mrgb/zadd/zsub/m(material) Leave only RGB on. Paint. Have Fun. Once you are done: -Go back to level 1 and import your saved uv .obj file, -go back again to highest subdivision level. -And press Color-To-Tex button in texture palette. Shazam!:D
thankyou soo much i can now do it!!!
thanks alot!!!:+1: :+1: :+1: :+1: :+1:
