Where is the setting to adjust the pinch on the Dam Standard brush? I cannot find it in the Brush Menu.
Brush:Modifiers:Brush Modifier (hold Ctrl over the slider for details). The Dam Standard brush is a Base Type: Standard brush so positive values of the slider affect the pinch. However if you’re after a stronger effect it might be better to follow up with the Pinch brush or create a new alpha and make a custom Dam Standard brush.
