I might be missing something obvious but I cant seem to find a way to change the resolution of the Curve Alphas. I would like to lower the resolution of the alpha projection.
Getting a low resolution result as the red lines indicate.
Hello @Hellothere
There is no way in the currently released program version to change the resolution of the alpha generated by the Curve Alpha brushes. It is possible that additional options may be added in future versions of ZBrush.
You can, however, create a mesh at exactly the resolution/topology you wish for use with the Extrude Profile brushes.
[Edit] If you’d like to start a conversation at Pixologic Support, we may have an additional option that will allow you to change the resolution for the Curve Alpha brushes. Just reference this thread.
Thank you!
